Just a small issue with how disks are numbered using a new feature in Opus 13.
Windows Computer Management shows the disks starting at Disk 0 when Opus starts at 1, not a huge issue but it would be nice as it may be confusing with lots of disks in a system.
I need to check if there's a reason we're using that numbering (maybe another part of the OS uses it) but if not, I agree it'd make sense to use the same convention as in Computer Management, and it should be easy to subtract 1 from the numbers on our side.
