@leo @jon
Please help test this plugin for memory leaks or cause dopus crashes, thank you!
DOpusViewerPluginSample.zip (837.1 KB)
library DOpusViewerPluginSample;
{ Important note about DLL memory management: ShareMem must be the
first unit in your library's USES clause AND your project's (select
Project-View Source) USES clause if your DLL exports any procedures or
functions that pass strings as parameters or function results. This
applies to all strings passed to and from your DLL--even those that
are nested in records and classes. ShareMem is the interface unit to
the BORLNDMM.DLL shared memory manager, which must be deployed along
with your DLL. To avoid using BORLNDMM.DLL, pass string information
using PChar or ShortString parameters. }
{$IF CompilerVersion >= 21.0}
{$WEAKLINKRTTI ON}
{$RTTI EXPLICIT METHODS([]) PROPERTIES([]) FIELDS([])}
{$ENDIF}
{.$DEFINE USERDEFINE}
{$IFDEF USERDEFINE}
{$DEFINE INIT}
{$DEFINE INITEX}
{$DEFINE USBSAFE}
{$DEFINE UNINIT}
{$DEFINE IDENTIFY}
{$DEFINE IDENTIFYFILE}
{$DEFINE IDENTIFYFILESTREAM}
{$DEFINE IDENTIFYFILEBYTES}
{$DEFINE LOADBITMAP}
{$DEFINE LOADBITMAPSTREAM}
{$DEFINE LOADTEXT}
{$DEFINE SHOWPROPERTIES}
{$DEFINE SHOWPROPERTIESSTREAM}
{$DEFINE CREATEVIEWER}
{$DEFINE CONFIGURE}
{$DEFINE ABOUT}
{$DEFINE GETFILEINFOFILE}
{$DEFINE GETFILEINFOFILESTREAM}
{$DEFINE SETMETADATA}
{$DEFINE VIEWERCACHELOAD}
{$DEFINE VIEWERCACHEFREE}
{$ENDIF}
{.$R *.res}
{$R *.dres}
uses
System.SysUtils,
System.Classes,
Winapi.Windows,
Winapi.Messages,
Vcl.Forms,
Vcl.Controls,
Vcl.StdCtrls,
Vcl.ComCtrls,
DOpus.ViewerPlugin in 'DOpus.ViewerPlugin.pas',
Unit1 in 'Unit1.pas' {Form1};
{.$IF VIEWERPLUGINVERSION < 5 AND Defined(USBSAFE)}
{.$R USBSafe.res}
{.$ENDIF}
const
DVWClassName: PChar = 'DOpus.ViewerPlugin';
function DVP_Load(Filename: string): BOOL;
begin
Form1.edt1.Text := Filename;
Result := True;
end;
procedure ReleaseResources;
begin
UnregisterClass(DVWClassName, HInstance);
Form1.Close;
FreeAndNil(Form1);
PostQuitMessage(0);
end;
function WindowProc(hWnd,Msg:Longint; wParam : WPARAM; lParam: LPARAM):Longint; stdcall;
begin
case Msg of
DVPLUGINMSG_LOAD : Result := DVP_Load(PChar(lParam)).ToInteger;
WM_DESTROY: ReleaseResources;
else
Result := DefWindowProc(hWnd,Msg,wParam,lParam);
end;
end;
function RegisterWindowClass(hDllModule: HMODULE): ATOM;
var
wc : WNDCLASS;
begin
// Register window class
wc.style := 0;
wc.lpfnWndProc := @WindowProc;
wc.cbClsExtra := 0;
wc.cbWndExtra := 0;
wc.hInstance := hDllModule;
wc.hIcon := 0;
wc.hCursor := 0;
wc.hbrBackground := COLOR_WINDOW + 1;
wc.lpszMenuName := 0;
wc.lpszClassName := DVWClassName;
Result := (RegisterClass(&wc));
end;
function UnregisterWindowClass(hDllModule : HMODULE):Boolean;
begin
Result := (UnregisterClass(DVWClassName, hDllModule));
end;
function CreateViewerWindow(hDllModule: HMODULE; hWndParent: HWND; lpRc : TRECT; dwFlags : DWORD): HWND;
type
NVC_CreateParams = record
lpRc : PRECT;
dwFlags : DWORD;
end;
var
wrc : TRECT;
cp : NVC_CreateParams;
dwExStyle : DWORD;
begin
GetClientRect(hWndParent, &wrc);
cp.lpRc := @lpRc;
cp.dwFlags := dwFlags;
dwExStyle := 0; //WS_EX_NOPARENTNOTIFY;
// if (dwExStyle or (dwFlags and DVPCVF_Border)) <> 0 then
// dwFlags := WS_EX_CLIENTEDGE
// else
// dwFlags := 0;
RegisterWindowClass(hDllModule);
Result := CreateWindowEx(
dwExStyle,
DVWClassName,
nil,
WS_CHILD or WS_VISIBLE or WS_CLIPCHILDREN or WS_CLIPSIBLINGS,
lpRc.left, lpRc.top, lpRc.right - lpRc.left + 1, lpRc.bottom - lpRc.top + 1,
hWndParent,
0,
hDllModule,
@cp);
// MessageBoxW(0, PChar('Result: '#13#10'hWndParent: ' + IntToStr(hWndParent) + #13#10'HInstance: ' + IntToStr(HInstance)), 'CreateViewerWindow', MB_OK);
if not Assigned(Form1) then
Form1 := TForm1.CreateParented(Result);
// Form1.Parent := FindControl(Result);
// Form1.SetBounds(lpRc.Left, lpRc.Top, lpRc.Width, lpRc.Height);
if not Form1.Showing then
Form1.Show;
end;
const
//press Ctrl + Shift + G get new PluginGUID
Plugin_GUID : TGUID = '{1362C93C-4F72-4AA6-AE1B-DD325B95922E}';
Plugin_VersionHigh : DWORD = $00000000;
Plugin_VersionLow : DWORD = $00000001;
Plugin_HandleExts : PChar = '*.*'; // separated by ";", example: '.txt;.html'
Plugin_Name : PChar = 'Plugin Sample';
Plugin_Description : PChar = 'DOpus Viewer Plugin Sample';
Plugin_Copyright : PChar = 'Copyright (C)';
Plugin_URL : PChar = '';
Plugin_MinFileSize : DWORDLONG = 0;
Plugin_MaxFileSize : DWORDLONG = $01400000; // 20971520(2Mib);
Plugin_MajorFileType : Word = DVPMajorType_Other;
function MAKE64BITVERSIONNUMBER(a,b,c,d: DWORD): DWORD64;
begin
Result := ((DWORD64(a)) shl 48) + ((DWORD64(b)) shl 32) + ((DWORD64(c)) shl 16) + ((DWORD64(d)) shl 00);
end;
//{.$IF VIEWERPLUGINVERSION < 5 AND Defined(USBSAFE)}
//function DVP_USBSafe(pUSBSafeData: PUSBSafeData): BOOL; cdecl;
//begin
// Result := True;
//end;
//{.$ENDIF}
{.$IFDEF UNINIT}
procedure DVP_Uninit; cdecl;
begin
end;
{.$ENDIF}
function DVP_Init: BOOL; cdecl;
begin
Result := False;
end;
{.$IFDEF INITEX}
function DVP_InitEx(pInitExData: PDVPInitExData): BOOL; cdecl;
begin
end;
{.$ENDIF}
function DVP_Identify(InitInfo: PViewerPluginInfo): BOOL; cdecl;
begin
Result := False;
InitInfo^.dwFlags := DVPFIF_ExtensionsOnly or DVPFIF_InitialDisable;
InitInfo^.dwVersionHigh := Plugin_VersionHigh;
InitInfo^.dwVersionLow := Plugin_VersionLow;
InitInfo^.lpszHandleExts := Plugin_HandleExts;
InitInfo^.lpszName := Plugin_Name;
InitInfo^.lpszDescription := Plugin_Description;
InitInfo^.lpszCopyright := Plugin_Copyright;
InitInfo^.lpszURL := Plugin_URL;
InitInfo^.dwlMinFileSize := Plugin_MinFileSize;
InitInfo^.dwlMaxFileSize := Plugin_MaxFileSize;
InitInfo^.dwlMinPreviewFileSize := Plugin_MinFileSize;
InitInfo^.dwlMaxPreviewFileSize := Plugin_MaxFileSize;
InitInfo^.uiMajorFileType := Plugin_MajorFileType; //DVPMajorType_Other;
InitInfo^.idPlugin := Plugin_GUID;
Result:= True;
end;
function DVP_IdentifyFile(hWnd: HWND; lpszName: LPSTR; lpVPFileInfo: PViewerPluginFileInfo; hAbortEvent: THANDLE): BOOL; cdecl;
begin
Result := False;
if not Result then
begin
lpVPFileInfo^.dwFlags := DVPFIF_CanReturnViewer;
lpVPFileInfo^.wMajorType := Plugin_MajorFileType;
lpVPFileInfo^.wMinorType := 0;
lpVPFileInfo^.szImageSize.cx := 0;
lpVPFileInfo^.szImageSize.cy := 0;
lpVPFileInfo^.iNumBits := 0;
Result := True;
end;
end;
function DVP_CreateViewer(hWndParent: HWND; lpRc: TRect; dwFlags: DWORD): HWND; cdecl;
begin
// dwFlags := DVPCVF_Preview;
// TDVPViewer.CreateParented(hWndParent);
// SetWindowLong(TDVPViewer.Handle, GWL_STYLE, GetWindowLong(TDVPViewer.Handle, GWL_STYLE) or WS_CHILDWINDOW);
// DVPViewer.Parent := FindControl(hWndParent);
Result := CreateViewerWindow(HInstance, hWndParent, lpRc, dwFlags);
end;
// exports DVP_InitEx name DVPFUNCNAME_INITEX;
// exports DVP_Uninit name DVPFUNCNAME_UNINIT;
exports DVP_Identify name DVPFUNCNAME_IDENTIFY;
exports DVP_CreateViewer name DVPFUNCNAME_CREATEVIEWER;
exports DVP_IdentifyFile name DVPFUNCNAME_IDENTIFYFILE;
// exports DVP_Configure name DVPFUNCNAME_CONFIGURE;
begin
ReportMemoryLeaksOnShutdown := True;
end.
