(This sub-thread was moved here, out of the Syntax coloured source-code viewer (32 & 64 bit) plugin thread.)
That’s a great little tool. It’s a shame that the language config is stored in the SourcePreviewHandler.dll.
In case you didn’t know, this tool uses the Scintilla.dll viewing engine which is also what Notepad++ uses. Notepad++ stores its config in XML files langs.model.xml and stylers.model.xml. This same exact same config is stored in the SourcePreviewHandler.dll.
It would be a nicer if the config was move to similar files, then we could add languages that were not included, or just copy it from notepad++.
I have not tried to create a Windows Preview Handler, but am interested. Seems to me that a lot of the work is already done, Scintilla.dll can display and format the text, Notepad++ has config for many different languages.
Would anyone be interested in working on one?
I prefer to use C#.
