What is the "multiview" plugin ? I have it in the list (disabled), but when trying to configure it, I can read "viewer dlls cannot be located", and all buttons are disabled in the viewerconfig... I tried to activate it, but it did not change anything.
It seems the algorithm used for resizing pictures (jpeg,...) in the dopus internal viewer is really bad when compared with DOpus 8. The one found in dopus 8 was a lot smoother: is there a way to set the quality/algorithm used when resizing pictures for the dopus internal viewer ? I had a look at the viewer settings, but couldn't see anything regarding quality/smoothing...
[MultiView viewer (various document formats))
Make sure this option is on. It affects the viewer as well as thumbnails:
Yes! that did it
I saw this option, but thought it was only affecting the lister thumbnails... and not the viewer it self.
Thanks
IMO the option should be removed, or moved to the Advanced section and set to high quality by default.
I doubt there are many computers left where high quality image scaling is a significant speed hit, and the low-quality option is fugly!
