When I copy or move multiple files I always run into this problem. Say I copy a folder from one lister to another. The copy window pops up to inform me of progress. This window is always in the centre of the screen. If I do 4-5 copies, I have 4-5 windows running in the screen centre. However I do a lot more copies than this, and it can get very confusing. FIrstly, there are so many of the darn windows, secondly (and mainly) they are all in the screen center, which slows me down a lot because i need to minimise or move each window.
What I would like to do is have the copy or move window to always appear in the bottom right of the screen. Is there any way to do this?
A related issue for me is Alt-Tab while doing the above. What I do is have multiple listers open. I am copy large batches of files between different locations (no, I do not want dual listers), and again there is a copy window running (does not matter if one or more for this question). The problem is when I alt-tab to swap listers, I always get the copy/move window instead of the file lister. This occurs regardless of which was open last - the lister or the copy window, despite that alt-tab should go to the last open window. It gets very confusing when there are multiple copy windows in progress. What I would prefer is never to alt-tab to one of the copy windows - thats probably not possible. However, at the least, alt-tab should go to the LAST open window (a lister), not always go to the copy progress window.
Thanks
