I've been using Power Toys recently and I have found the run application launcher / search bar very useful. The only issue is that it opens Windows Explorer instead of Dopus. Any options to redirect to Dopus?
Many thanks
Many thanks
Assuming Explorer Replacement is on in Opus, if it isn't working then it means PowerToys is doing something which explicitly runs explorer.exe (or the "open" verb if using ShellExecute on a folder) instead of the default file manager (or the null/default verb if using ShellExecute).
Similar to a program which explicitly runs Internet Explorer instead of the default web browser, you'll need to ask its authors to fix it.
Thanks Leo. Was worried you'd say that, but makes sense. Ill contact the devs and if I get any updates I will post back here.
Already raised:
I thumbed this up on github. (And that's a strange sentence to write.)
