Power View not available in one folder
I have a folder "Movies" on my external HDD. When I enter it, the Power View button disappears and I cannot enable Power View. In the parent folder, I can enable Power View.
I already tried the "Treat all virtual folders as real". That doesn't help, and the folder is not a virtual folder anyways.
Is there a fix for this? Am I doing something wrong?
By default Power mode buttons are hidden unless you're actually already in power mode, but you can re-enable them by turning on Preferences / File Display Modes / Power Mode / Display Power mode toolbar buttons.
Thank you, that solved it!
