I regularly create backups of the configuration, including all data such as icons. However, after updating to version 13, I encountered an issue where the toolbars and most icons were not carried over. All the colors from the toolbars were lost, and many of the icons disappeared.
Upon inspecting the directory "C:\Users\Mik\AppData\Roaming\GPSoftware\Directory Opus\Icons," I noticed that the entire structure of the icons was not as I had originally set up. I have encountered a similar problem in version 12 before, so I had backed up all the directories, including the Icons directory, in a secure location. It was only when I copied my icons back into the directory with the correct structure that all my icons were displayed again. However, the toolbar colors are still missing, and I'll have to manually recreate them. This will be quite time-consuming since I have a large number of Toolbars, and they are color-coded.
I believe that if I restore a complete backup, including all data, and allow it to overwrite the old configuration, I should be able to restore everything to its previous state.
