Print Folder -> Exclude locked ZIPs
Hi all!
How to setup Print/Export Folder Listing in order to skip archives (ZIP, RAR, etc.) protected by password?
Now it hangs on every protected archive to enter the password.
Try adding a filter that uses IsEncrypted.
It works! Thanks a lot!
Another side: is there a way to pass specific password to all the archives (if it is inappropriate - to skip the archive)?
Not sure I understand the question. Do you mean the script column? And which password is inappropriate?
Now my question no longer makes sense. And here's why.
Initially I thought Print Folder required a password to open the archive to print out it's file structure. But now I see that the password is only needed just to show uncompressed size of archive's contents...
Is it expected behavior? I think it's incorrect. I expect to see the compressed (real) size of ZIP file. Am I wrong?
It depends a lot on the archive type, and how the archive was encrypted. Some archives only encrypt the data and let you list the files without a password. Some require a password to open the archive at all.
Why Print Folder prints uncompressed size of archive contents instead of actual ZIP-file size?
Isn't it a bug?
Please start a new thread for new issues, and give more details / examples.
