I thought I would post this help request so one of you gurus could answer it.
Please see the link below:
forums.whirlpool.net.au/forum-re ... ?t=1128971
[quote]I am trying this program out, and it has a PRINT FOLDER option which is a great idea but I would
like to just print the folder names and no files but can't figure out how to do this trick ???[/quote]
1. Create a simple filter which matches the special [Folders Only] file type.
(look here: [Recreate Empty Directory Structure))
2. Click Tools -> Print Folder and use the filter Folders Only
You also might want to take a look at this:
softwareok.com/?seite=Freeware/DirPrintOK
Thanks guys.
The filter worked after I had created it.
