Print screen qualifyer?
Hi!
A small question:
How to use the prt sc key to get a screen dump and paste it into fileview?
I used to know this but have just forgotten how. :slight_smile: Must be the age thingy :slight_smile:
Thanks in advanced!
Todde
Press PrntScrn to put the screen into the clipboard (or Alt-PrntScrn for just the active window), then Ctrl-V paste into any lister.
The same works with text in the clipboard, as well as images from other sources.
Hi!
Thanks!
I took me a while to figure it out, but after a couple of tries i found the qualifier.
Todde
