I'm attempting to get the Advanced FTP plugin working and have reached a problem.
I've got FileZilla Server v0.9.8 on the server. I've set the port to 2100, turned on passive transfers using the default ports, MODE Z is on, as is SSL/TLS & explicit connections are allowed, and I set it to listen to both 2100 and 990 for explicit SSL/TLS connections.
On DOpus I set it to "Secure TLS/SSL Explicit", the correct port number correctly and enabled passive mode.
Note that these settings with with the FileZilla client.
When I connect with DOpus I can see it saying:
[quote]AUTH TLS
334 Using authentication type TLS[/quote]
then it just sits doing nothing.
When I change DOpus to do "SSL Implicit" and change the port to 2100 it tries connecting but this shows in the FileZilla Server log:
[quote]> Connected, sending welcome message...
220
(binary)(binary)
500 Syntax error, command unrecognized.
a(binary)
](binary)
(lots of binary data)
6
9
8
5
(binary)
(binary)
3
2
(binary)
f
(binary)
(binary)
c
b
a
(binary)
(binary)
500 Syntax error, command unrecognized.500 Syntax error, command unrecognized.
e
d
(binary)
(binary)
(binary)
(binary)
(binary)(binary)
(binary)20
[/quote]
Anyone have any idea what I need to change? Has anyone gotten the Advanced FTP plugin running with FileZilla Server?
Any help would be appreciated.
Thanks.
Damien
