I have batch-rename defined which does this:
Old Name
([0-9][0-9][0-9][0-9][0-9][0-9][0-9]_)(.)(..)
New Name:
\2.txt
It gets rid of 7 digits and a _ at the beginning of the filename
example:
2175650_TTC_-_Biology__The_Science_of_Life.txt
turns into
This works fine in the rename process. But have not been able to create a button which would do the exact same thing for me.
Any solution for me?
Best regards!
Leo
2
Rename PATTERN="([0-9][0-9][0-9][0-9][0-9][0-9][0-9]_)(.*)(\..*)" TO="\2.txt" REGEXP
There are a few similar examples in my Getting to know... tutorial.
Cool! Will give it a try once I get home ( and also check out your tutorial ). Thanks!!
Leo
4
I linked to page 4 BTW. Scroll up for the table of contents if you want to start from the beginning of it.
Thanks! Works like a charm - I am very happy camper now
