Problem to fix an image vertically or horizontally
Hello,
Could somebody explain me how to fix definitelly an image horizontally or vertically ?
I try to use the Convert option in the Tools menu in selecting the good degree. It works in the preview small screen but nothing is modified after the confirmation.
Thanks a lot for your help
What do you mean by "fix"?
Could you post a screenshot of what you've set in the Image Convert window?
Hello
What do you mean by "fix"? Forget it. I made a mistake.
I'm going to be more exact.
This is what I observe. Wen you convert an image for what you want and select the option "Write converted images in the destination file", nothing appends. No new file with the correction, no corrections on the original image.
If you deselect the option, you obtain a new image with the correction.
So this is my question : why the correction isn't apply on the original image when I select the option "Write converted images in the destination file" ?
If you have the solution about this mystery ...
Thanks a lot for your anwers.
When the option is turned on the converted images are saved to the "destination" folder. In other words, the folder in the file display which is marked as destination (or "dest" for short).
If you ran the conversion from a dual-display window then the destination will be the folder in the other half of it. If you launched from a single-display window then the destination will be one of your other single-display windows. (If only one file display is open then you should be prompted for a destination when the option is on.)
When the option is off the results are written to the same place as the original files.
So I suspect everything has been working fine and you've created some converted images in folders that you didn't expect them to go to, so you'll probably find the results on one of your drives.
Hello,
I start to understand.
I come from to read the help file also.
One question : If I have only one Lister opened, and if I convert an image, does it mean that with the option 'Write converted images in the description folder ", the image won't be converted ? Do I have to have a dual display in a lister or two listers actived ?
To be more precise, Describer displays a description of a folder in explorer mode on the left part when the option of explorer "Display as a web page " is activated.
If you only have one lister open then I think you'll be asked for a destination folder. Try it and see to be sure.
Sorry. I mixed two posts and the last about Describer wasn't for this post.
And to answer to your advice to try one lister, it's for that I posted this message. When I try to convert an image in one lister,, nothing appends. DO doesn't ask me the destination folder. it doens't convert the original image. It doesn't create a new converted image.
On the other hand, as you told me, if I use two Listers or a dual-display in a lister, it works.
Your opinion ?
I just tried it and if there's only one lister open the checkbox at the bottom of the dialog is disabled and cannot be turned on at all. So if you turned it on then there must have been another lister open somewhere and that's where the files went.
(Unless there's an issue in the translation, since I only tried with the 8.2.2.5 English Unicode version of Opus, but AFAIK that couldn't cause this type of problem.)
