During installation of Directory Opus, I went with all the defaults.
After the installation, when any .txt file is clicked I was prompted to select the program to open with. Even if I have chosen to always have these files open with Notepad, this option didn't stick.
I then created a user command to open selected files w/ EditPlus and since then surprisingly all .txt files are opening with EditPlus even if I have not actually clicked the 'Open with EditPlus' button that calls the user command.
I want to associate .txt files with Notepad.
When I right click in the empty space of a lister, there is no choice to create a new text file under New.
On a possibly related note, nothing happens when I click on a button that has the following code:
FileType NEW=.txt NEWNAME="norename:{dlgstringS|Enter filename|temp.txt}"
Please help.
