I am ver 12.31
I am a photographer and use Dropbox. When using Opus all the images which are on the local computer are showing that they are 'available when online'. Is there some way to force Opus to refresh the 'Availability' column.
Example. As you can see the image preview is there but it shows the file is only in the cloud.
OK, is there a way to change to attribute for a whole folders?
The reason I need to show the files are local is I use the MD5 number for a random sort.
Let's say there are 100 images and I need to select 33 at random. the only way I have found to do that is to create the MD5 checksum and sort by that column and that acts as a random function.
I am a photographer and have liked using Opus and owned it for many years.
