In some cases, especially when parrent directory of currently displayed folder contains many sub-directories AND lister's window is located at right edge of desktop, dragging file/dir on "arrow" in location field causes displaying menu in such position that drop is not possible.
The menu is located at some distance from mouse cursor's position so if now cursor is moved toward desired element of the menu it inevitably will be moved outside of the menu.
Which in turn will cause a closing that menu.
Directory Opus Pro 11.4.3 (Beta) Build 5253 x64
OS 6.2 (B:9200 P:2 T:1) SP 0.0
- Improved placement of breadcrumbs pop-up menus when there isn't room for them in their usual bottom-right position.
Could you post a screenshot of the whole monitor (reduced in size, if possible) with the menu open in the wrong place? Maybe there is a scenario the code still doesn't account for which seeing the screenshot will reveal to us.
