Problem with Empty Recycle Bin with icon state
I've been using this button for a year, and it always worked great in version 12:
@icon:/system/SHELL32.dll#31,RECYCLEBINEMPTY
Delete EMPTYRECYCLE FORCE
But since I installed version 13, the icon for the empty recycle, which is the one linked within the command, is showing the default icon for DLLs rather than the referenced icon:
Confirmed, looks like a bug in the current beta.
(I also see it wrong when the recycle bin is empty and OK when it has things in it, same as you.)
That should be fixed in the 13.0.55 beta we just put out.
Fixed, the trash shows the appropriate icon either when it is full or empty.
I'm having another issue in version 13 still regarding icons, but in the context menu, at first, I thought it was correlated with the issue in the bin button, but it is still present after the update, I'm guessing it is better to create a new post for this.
