Hello
i got problem with filenames
please how to fix it ?
thank you
Hello
thank you
Are you using a pirate version, or maybe used one in the past and didn't fully remove it?
i use 9.5.6 trial version
Only known cause of that is pirate versions trying to stop Opus behaving normally. If it's not that, contact GPSoftware for help (you can use your eval licence to request support so long as it has not expired):
ok thank you
Hihihi
