Problem with image viewer
Hi. Until yesterday I was using an external app to open all mi image files. I decided to have DOpus do it since I find the image viewer very good. The problem I've run into is that although I have it set up to advance to the next pic on left mouse click, it doesn't do this. If I set it to close the viewer on left mouse click it'll work though.
Also, the previos and next icon on the toolbar of the viewer are disabled, they are unclickable. I've gone through Preferences and set it to generate Previous and Next lists as well, but to no avail. I am sure this is not a complicated problem, but I haven't been able to solve it following the logic presented though the configuration and preferences.
Thanks for your help.
Nevermind. It's always a good thing™ to read the Help file.
