I have a button to set Flatview on and then sort the display in reverse order by modified date. I use
Set FLATVIEW=On,MixedNoFolders SORTBY=modified SORTREVERSE=On
Then I have a button to reset those settings. I use:
Set FLATVIEW=Off SORTBY=name SORTREVERSE=Off
This seems to work fine until I switch to a new directory. The sort is still in reverse mode and sorting on the modified field. Is the above incorrect somehow or am I missing a command to make the change global?
Jack
