Problem with type Double in Evaluator Column
I'm playing around with Evaluator columns and can't get them to work with variables of type double. The most primitive example
x = 1185.15;
return x;
leads to an empty column and the error
Error at line 1, position 13
Unknown value (6): 1185.15
I also tried
x: double = 1185.15;
return x;
and even just
return 1185.15;
with the same result. Other types work just fine. I used 13.5 and now the latest Beta 13.5.5 and I'm not aware of any weird settings I might have changed to influence this.
Am I completely dense or...? :worried:
That's pretty odd... all examples work for me.
Thanks for trying, lxp.
Just in case this helps: My Windows is set to English but to the regional format "German (Germany)", so by default numbers look like 1.234.567,89. My "Size" column, for example, uses a comma: 5,39 MB.
Yep, with "German (Germany)" I see the same error... and there doesn't seem to be a workaround or setting available.
It's strange that this hasn't popped up before, there must be a few users that run the same format :wink:
"German (Switzerland)" works fine, btw.
The plot thickens... :smiley: Yes, I imagine I'm not the only one with these settings. But using Double values in Evaluator columns may be less typical...
Meanwhile I quickly moved my PC to Australia and "English (Australia)" which did change eg. the date representation in DOpus but it did not change the column issue. Weird.
Many thanks for the report. A fix will be in 13.6.1 (first beta after 13.6).
Using the latest beta 13.6.1 I played around a bit more and entered this:
i = 1 as double / 3;
Output(i);
Output(i as "%.3");
Output(i as "%.2");
Output(i as "%.1");
Output(i as "%.0");
i = 183743933;
output(i as "%.3kb");
The log shows:
 04.05.2024 14:11 Evaluator:  0.333333
 04.05.2024 14:11 Evaluator:  179.437,435 KB
The Double results seem to be off by one decimal place...
Also note that the filesize is formatted according to my locale (German/Germany), while the other numbers are not.
