When I double click on the bluetooth tray icon to open the bluetooth neighborhood I get first a request to move it (??) - first attachment of this message - then to copy it - second attachment - and then finally Dopus open on the bluetooth neighborhood.
This happens with multiple computers and with Widcomm and Bluesoleil stack, so I think is related to explorer. If I uninstall dopus, everything works well. If I install dopus again, the problem come again.
Try telling Opus not to handle the Bluetooth folder.
To do that go to Settings -> Preferences -> Launching Opus -> Explorer Replacement and select Replace Explorer for all but the following folders.
You then need to add the Bluetooth folder to the list. You can use the Add button above the list and browse for it, or you can drag & drop it into the list if you have it (or its parent) open somewhere.
