Hi all, whenever I open my laptop (and it wakes up from sleep), Directory Opus shows me this message for all open Google Drive folders.
Is there any way to solve this? All of my work folders are actually on Google Drive.
Many thanks ahead!
Many thanks ahead!
The options under Preferences / Folders / Auto-Loading can prevent loading folders until you actually use them.
Thank you for this tip! I changed it for "powered down" and "removable" but it keeps happening. Which is the relevant category for Google Drive? This is my current configuration:
Try changing all of them to see if it actually helps first.
Well, oddly it just works well now although I didn't change anything... Maybe it just needed a restart. Thanks again!
