Hey there,
I have been finding dOPUS very useful for some time in maintaining my large music library which is housed in duplicate on two 500gb drives, one internal one external. However I also have had a problem with CDs I was sure I had encoded seemingly disappearing from my library. Today I noticed what I think is the culprit. I copied The Streets new album ["Streets, The\Everything Is Borrowed"] to the "S" folder on my external drive, then I realised I hadn't finished tagging it. So I hit CTRL+Z. I noticed the folder "Streets, The" disappear, taking five other folders of music with it. It didn't just undo the copy it also deleted every other album in that artist's folder!!! Can anyone tell me a fix, or alternatively, a way to COMPLETELY disable undo in dOPUS.
Thanks
AB
This issue was addressed in a relatively recent update to Opus (I forget which exactly, but within the past couple of months). So make sure you are using the latest version (9.1.1.3)
thank you kindly, will have to update
