I was having some hang-up issues when using the find feature to search for files with specific content, given this I upgraded to 9.6 this morning only to find the same problem but now at least I get an error popup instead of the program just not responding until I force it by ending the opus directory task.
Ive attatched a screengrab of the message, it seems to be repeatable, actually making it more of a pain since I cant use this facility. Was searching some source code for a lua program which is purely text files. If I search for the word Target it works fine, if I search for what I actually wanted which is TargetDebuffButtonTemplate, it hangs with that messeage every time, I thought it might be cause I accidently pasted some control character at front/end of string but when typing that manually it still crashes.
Please let me know if you require any further info.
Does it only happen when searching certain files/folders? If so can you narrow it down to a particular file (or a few files)? If you can please upload them (or send them in a private message) and I'll see if I can reproduce the problem.
Leo, thanks for your response, Im trying to track it down to a file /directory but its slow going since the location im searching has about 100 directiories:
Not sure if it will help at all but on one crash i got the following when it stopped responding without a opus directory error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: dopus.exe
Application Version: 4.0.1.15
Application Timestamp: 494c61e6
Fault Module Name: StackHash_e9d5
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791adec
Exception Code: c0000374
Exception Offset: 00000000000a6e97
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 2057
Additional Information 1: e9d5
Additional Information 2: 6ad54c25dc36cbecc6163f0b5ee47f06
Additional Information 3: 9c1c
Additional Information 4: ffa7ea7f0b53491907ca741f66cfde94
Leo, I've managed to track it down to a few files, Its a .LUA files which is the coding language im using, the files in question arnt mine but I can tell you they contain characters for other languages and I believe that is whats causing the problem. Thing is they are valid files, ie not corrupted, they just contain localisation strings for other languages.
