Hello everybody
I wish to know if is possible to put two or more folder exclusion in this window :
Best Regards
Hide Folder - Folders
How can I put three folders . By example :
Best Regards
I have tried to separate them by differente symbols with no result : , ; / : ......
In Opus filters, you use the pipe symbol | to separate items.
(train2|wait1|spac1)
Nice indeed.
Big program.
Best Regards.
When I filter a folder I observed the files or subfolders filtered don't appear in the list.
But I would like that the size would be the corresponding to the filtered folder, not to the initial folder.
Is it possible ?
How can I compared two filtered folders to see if they are equal to each other under the filtered option ?
I've never tried it, but in theory you might be able to do this using the Synchronize utility panel with a saved filter.
By the way, it's best if you only ask one question in each thread. When you ask more than one question in the same message thread people may not see the second question and not answer you. So if you have more questions, please start a new thread for each question.
Okis. I will do more accurate questions in parallel posts.
Best Regards
