Go PATH=/downloads FOLDERCONTENT="maxwidth=83,showempty,maxdirs=20" USEQUALKEYS
Small correction: qualifier keys are already working as intended.
When Ctrl or Shift is pressed, the correct behavior is triggered regardless of which pane has focus in dual display.
The issue is specifically with the default/no-qualifier behavior. OPENINLEFT appears to have no effect — instead of always targeting the left/top pane, it simply opens in whichever pane currently has focus (left/top or right/bottom).
Other arguments seem to work correctly; only OPENINLEFT is being ignored or overridden by the active source pane.
After looking in detail, the go_usequalkeys_eval Evaluator script only gets called when a qualifier is down.
I don't think there is currently a way to add default arguments to the Go FOLDERCONTENT command and then remove some of them via go_usequalkeys_eval when a qualifier is held down.
The KEYARGS method you already found is probably the best option at the moment.
We'll have a think about if we can make this more flexible, without breaking people's existing configurations.
Any chance of FOLDERCONTENT being able to return folders sorted by modified date or created date? I just noticed it seems like only files can currently be sorted, unless I’m missing something.
It’s kind of needed with all these new copy-to and copy-from features, since it’s usually the most recently edited folder you need to manage. This would also be really handy in huge folders like the Downloads folder.
