Hi, quick question. I just want to know if I understand DOpus correctly.
If I want a hotkey to change some Preferences option on the fly, there needs to be an existing, specific internal command for that option. It's not the case that I could write a script to automate opening Preferences, navigating to the appropriate tab and changing the option.
Am I correct in my thinking?
I just had a thought that I could make hotkeys for pre-setting the slideshow speed, but couldn't see a command for that. I wondered if I could solve it with a script, but from what I can figure that's just not how scripts work, right?
Thanks for any reply.
