Hello. I'm thinking of trying the trial of Dopus to use it on a PC and laptop. But since it is a complex program, I wanted to know a few things that are essential for me before I install the trial.
1 - The Directory Opus Pro Single license says I'm able to use it on "Single machine license plus one personal laptop". However, I use a big laptop as my fixed desktop computer and a separate ultrabook as my personal laptop. Will I still be able to use this license?
2 - Is there any way to sync settings and configs between these two devices? Or do I always have to configure them separately? If I change something on one device, will it sync to the other?
3 - If I apply tags to files that are synced through OneDrive and iCloud are the tags kept? Will I be able to see tags on both devices as long as I have Dopus installed on both? Will I have to apply tags on a per-device basis? Are tags only visible on the device they were created?
4 - What about file collections? Can these be kept synced between devices (using the same relative file-paths), or do I always have to create them on a per-device basis?
I've been trying to search for answers to these on the forums and internet for the past few days, but I can't seem to find definitive answers...
Thanks in advance
