I noticed that when enabling the PowerToys Source Code (Monaco) preview handler, a warning message appears:
"PowerToys Source Code (Monaco) is enabled. You should disable it as it will override the superior Directory Opus text viewer."
I’m curious about the reasoning behind this. In what specific ways is the native DOpus text viewer "superior"?
The native viewer doesn't include built-in syntax highlighting for code, whereas the PowerToys handler provides color themes and highlighting for various programming languages, which I find very helpful.
If I choose to ignore the warning and keep this PowerToys Source Code Preview plugins enabled, am I missing out on any critical DOpus features or potentially causing stability issues?
