Please excuse me for reviving this old thread, I have some questions the help file / manual does not answer. And my technical understanding goes not far enough as to deduct the information from the posts above.
The manual says that file operations (like renaming, copying, moving) can be done with the entries in the collection, but what about the original files, in different scenarios?
- Original file (in its original, "physical" place) renamed: Will the new name show in the diverse collections this file is listed? (It's evident that is always wanted.)
1a) Ditto but rename within a collection: Will the rename there replicate to the original file? (It's evident that is NOT always wanted, but in most cases.)
1b) Ditto (as in 1a): Will the rename there (i.e. in the collection) replicate to this file's entries in other collections? (It's evident this is not always wanted either. Not doing this would only make sense of course when there is a NO to 1a).)
2a), 2b), 2c) for moving instead of renaming. (If de-synched renaming is possible, i.e. renames of the entries in collections, without breaking the link to the original file, it would of course be important for all links to be upheld, and changed accordingly for the move (new path for the link, i.e. for the collections / xml file entry), not affecting the list names, be they identical to the name of the original files in question, or some individual aliases, from renames having occureed in-between.)
3a), 3b), 3c) for deleting. Deletion of the original file should of course delete all occurrences in collections, too (previously renamed or not over there, in case such renames which do not affect the original file are possible), and deletions in collections should only delete the occurrence / entry over there, NOT the original file - but there could be a special control-delete (i.e. additionally) over there which would indeed also delete the original file, after a security dialog of course (even though you rarely press control-delete inadvertantly).
- I hope very much for some of this functionality being implemented, would happily buy DO in this case. This would probably suppose that the functionality only works without fault when ALL the above renames, moves, deleted will have been done within DO, i.e. I would be willing to shift all of my file management to DO in order to have this functionality. But please state in case some functionality of the ones described even work correctly after some processing with other file managers, e.g. in special "monitored folders" or such.
From the posts above, I deduct that the user could implement that functionality (1)-3) and/or even 4)) themselves, with scripting and accessing the XML file, but since I'm not able to write such scripts, I would like to have at least some of it ready-made, in a file manager I can buy in order to have that functionality.
Please forgive my questions, instead of just trying it all out with dummy files, but in case this functionality has not yet been implemented, I would like to be able to trial DO at a later time when this functionality will (partly or fully) be there, and trialling DO now, without knowing, would prevent my possibility to do so later on.
Thank you very much!
