Breaking the rule of one question per thread, these are closely related, so I'm combining them. Since it's possible to search for duplicates based on a previous Everything query in the same command, I've noticed two small issues that I wanted to bring to your attention.
When using
FIND
withDUPES
and the Everything engine,IN
must be included even if it's not being used.E.g.:
FIND CLEAR DUPES SIZEONLY IGNORELINKS SHOWRESULTS=dest,tab IN /home QUERYENGINE=everythingglobal QUERY "{alias|dopusdata}"
\home
is ignored but required to run the command. -
When using
FIND
withDUPES
and the Everything engine, addingCOLUMN
doesn't search for duplicates (the search results from Everything remain unchanged). It seems that it only works when you includeMD5
.Doesn't work:
FIND CLEAR DUPES COLUMN=ext IGNORELINKS SHOWRESULTS=dest,tab IN /home QUERYENGINE=everythingglobal QUERY "{alias|dopusdata}"
Works:
FIND CLEAR DUPES COLUMN=ext MD5 IGNORELINKS SHOWRESULTS=dest,tab IN /home QUERYENGINE=everythingglobal QUERY "{alias|dopusdata}"
Thanks in advanced.
