Hello,
I have set a series of non-substitution options when initializing, why doesn't it count after opening it? For example, the boot boot is still here.
the version I'm using is 12.33.
Best regards,
Shige Li
That's DOpusRT.exe rather than DOpus.exe itself. It uses almost zero resources, and is there because you have the Desktop Double-Click option turned on.
I see, it is needed for the double-click effect, and the program itself does not start.
