I want a quick filter for files that begin with arbitrary characters like "abc" or "xyz". I tried
Set QUICKFILTER=regex:^(abc|xyz)
That filtered out everything even the files that matched the patter
Try adding .* to the end.
Behaved the same with .*
screenshots
Set QUICKFILTERFLAGS=regexpon
Set QUICKFILTER="^(abc|xyz).*"
Works in my tests.
Yes yours works, thank you
You can set both things at once as well:
Set QUICKFILTERFLAGS=regexpon QUICKFILTER="^(abc|xyz).*"
(Might make a difference in a directory with a lot of files.)
I tried:
and got error
https://imgur.com/a/I9j9a5W
You forgot the leading Set.
