Quick Tip for restoring filter label definition
After upgrading from DO12 to DO13, I've lost the filter definitions for my label assignments.
Currently the definitions look like this.
Unfortunately, I can't remember what I've set up in the past, just remember about a script column, which is still there, but the filter is empty or somehow "re-defined".
I've backups of DO12`settings, can I extract, lookup the definitions there?
The info would still be there, certainly - but can you clarify what's been lost? WHat in that screenshot is wrong?
I'm missing the essential part: a script column calculates a date from the filenames and a label assignment previously colorized each row in the lister in red color, when the date of the script column is higher or equal current date.
Or marks the row in yellow color if the date in the script column is current date minus x weeks.
This is out of my memory, but this is not what both definitions currently do.
They aren't in the previous/parent Prefs page, are they? The "...In Specific Folders" one only contains labels which would have been assigned via Folder Formats in Opus 12, while global labels are in the page above (same as in 12).
If they would still exist, I expect some of the rows to be in red or yellow colors: Some of the dates apply, e.g. date is lower than current date, but the rows are not colorized as they were before upgrading.
The screenshot above is what I currently see in "Specific Folders". Unfortunately the definition is incomplete. Btw, why is the a small sign on the right side of the filter labels?
grafik
Ah, guess I found the problem, the filter did use the wrong script column. Instead of "Backup Method" this should read "Warranty Expired".
After changing the definition, the row's colours are back again! This still leaves the question: Why were those filter not migrated properly since they worked flawlessly before upgrading to DO13?
If you can send us your config backup from Opus 12 we can try and work out what went wrong. Either PM it to Leo or myself or email it to crashdumps@gpsoft.com.au. Thanks!
