Trying to set a QUICKFILTER for an evaluator column, year,
eval:Year in Filename is the name returned from Clipboard SET %headerkey%
Having some problems trying to get it to work, the following does not work
Set QUICKFILTER=eval:Year in Filename==2008
Year is a string not a number
Remember quotes if there are spaces in an argument value.
Also need QUICKFILTERFLAGS to enable the evaluator mode (unless it's on by default).
Using
Set QUICKFILTERFLAGS=evalon,regexpoff,partialon,anywordon,ignorediacriticsoff
did not want to confuse the OP with too much information.
Tried
Set QUICKFILTER="eval:Year in Filename"==2008
Set QUICKFILTER="eval:Year in Filename"=2008
Set QUICKFILTER="eval:Year in Filename"=="2008"
Set QUICKFILTER="eval:Year in Filename"="2008"
Set QUICKFILTER="eval:Year in Filename==2008"
with no luck, was hoping there was some method I have not thought of.
Try
Set QUICKFILTER="Val(""eval:Year in Filename"")==""2008"""
Thats the magic, many thanks Alexander ![]()
