95% of the time when I'm looking to compare files for duplicates, I'm looking at a horizontal layout and I want to compare pane A on top to Pane B on the bottom.
When i launch the dupe checker, it always has the folders i selected last. It would be handy if I had an option to say "Pane A" or "Pane B" as I usually have to fidget with the folders and clear out the last search.
(Some icons next to the "Select Folders" "Remove Folders" buttons on the toolbar to add these panes would be handy.)
Short of that, is there a way to set up the dupe checker to compare whats in Pane A to Pane B -- regardless of the folders? Maybe with a script?
Add the CLEAR argument, else it will add the new results to the old ones, which is why it looks like it's searching previous folders. (It isn't, it's just keeping the old results.)
Just to give you another option, you might want to checkout the CompareEx script addin as well. It will select dupes directly in the file displays and also supports folders and flatview. It's by no way a replacement to the "Find" command and DOs find-duplicates function, but for an alternative approach to comparing the content of two file displays its probably worth giving a try. Find it here (in the german DO support forum): https://www.haage-partner.de/forum/viewtopic.php?t=4956
Make sure to install the script addin and the belonging button for easy access.
