I cannot change from windows search, whether I click on an evrything option or use cursor keys and return it does not change, Everything is installed and running on startup, works fine in stand alone mode. I cannot chane to Opus search either
I'm using V13.10.1 (all preveious V13's have had the same problem) and Everything V1.4
I have tried disabling all winaero tweaks (only had 11) and it made no difference, I removed the launch command under advanced settings as it's launched on startup with no difference.
I would reset the Opus configuration, and if the problem persists, refresh the drivers for pen support, graphics, and other specialized hardware components. A screen recording might provide further insights.
