From the docs:
Is my observation correct that the random number is never zero or one?
It's 0 < Rnd() < 1?
From the docs:
It's 0 < Rnd() < 1?
Statistically I would think that the population of random numbers would would have to have definite endpoints.
https://csrc.nist.gov/glossary/term/random_number#:~:text=Definitions%3A,a%20uniformly%20distributed%20random%20process.
0.0 and 1.0 should both be possible, but there's only an approximately 1 in 4294967295 chance for both of them, so you'd be unlikely to observe either of them without a lot of luck.
Which makes me wonder, what kind of test lxp had this observation derived from.
Apparently, in JScript's Math.Random the range is [0, 1)
random Method (Windows Scripting - JScript)
In my memory this would be notated [0;1[ ... but notations could vary from one country to another!
F5 and an itchy trigger finger ![]()
Deleted
A cherry keyboard's key is said to take around 50,000,000 presses. Means, you must have been wasting almost 86 of them.
What matters to me is how many unique random numbers are within that range and what prime numbers divide that.
The answer is 42
Well if f(x) = C, an integer , it is independent of the integration anyway .
