Hi
I'm trying to hide my ready boost drive from the toolbar and have tried adding a user command
Go DRIVEBUTTONS=-f
which corresponds to the ready boost drive F:
It doesn't work, can anyone help please?
thanks
Hi
Go DRIVEBUTTONS=-f
thanks
Try Go DRIVEBUTTONS=cdrom,network,removable,hideempty,-F.
Also, make sure, you don´t add just another drives bar. Edit the second one instead, which is usually
for the removable drives.
Brilliant that works. Thanks abr.
