Recycle Bin context menu editing possible?
So the Recycle Bin, I have it in the Favourites toolbar.
Right Click Context menu, I only ever need is
Empty
Open in Opus
Can I remove every other entry?
The context menu for Recycle Bin is generated by Windows. Anything that can edit it in File Explorer should also work win Opus, but there isn’t an easy way to edit it that I know of.
