Redate after Exif
Up front, I know there is a posting from Leo (Set Shooting Time). I have installed the button, selected files, click button, nothing changes.
Don't know why, installed it as per instructions.
Anyway, I want to change the "Modified" date to date/time digitized (shooting time).
Usually I would select the files, RMB Click Rename, but I am not sure if files can be redated thére.
Any help wud be appreciated!
TIA
Is this the button you tried? Set Created/Modified timestamps to EXIF Shooting Time
Does Opus report that the files actually have shooting-time information? e.g. By turning on the appropriate Picture column.
This is the button indeed and these are files directly from my camera.
I can change the modified date alright, but need to launch another application to do the job.
When running the other application, I see the modified dates in DO are changing (in background).
Does Opus report shooting times for the files if you turn on the shooting-time column?
Yes, it does, I usually donot select this column though.
My button should work then, and still works for me FWIW.
Do you have Opus installed in the standard place? If not, did you edit the button as per the instructions?
If you make a button which runs this, does it work on one of the files?
SetAttr MODIFIED="2010-02-03 01:23:45"
:blush: :blush:
Argghh...
Did not edit the path-thing.
What a shame!
Feel terribly embarrassed...
Is there a way to delete an entire thread... :wink:
Sorry!!
Oh Oh...
(it works fine now - many thanks)
