Hi,
I've edited the CTRL-3 button to add "PRESET=last", which technically works perfectly, however, during development, I would like to be able to save changes to the preset using "Ctrl-S".
The problem is, when I trigger "rename advanced preset=last", it doesn't remember WHICH preset was loaded, just the preset settings. As a result, pressing "Ctrl-S" asks me which preset to save.
Even right-clicking on the Saved preset and selecting SAVE forces me to type the name out manually and respond to the "Replace?" dialog.
Would it be possible for PRESET=last to remember the NAME of the last preset loaded?
Would it also be possible to allow "Save" from the context menu of a preset automatically overwrite that preset? You might also consider adding "Save As..." to the context menu which appears when right-clicking on an empty area in the preset column (in addition to the existing import/export menu options.)
Thanks
