Rename command with TO and CASE arguments
I create vbscript to rename parent folder with part of selected file name and I notice that if I have Rename command with TO and CASE arguments, arguments are forgotten.
After some others test, I found 2 simple commands examples...
Rename TO=test CASE=allwords
Rename TO={sourcepath|nopath|noterm} IGNOREEXT CASE=allwords
It works if you add PATTERN=*:
Rename PATTERN=* TO={sourcepath|nopath|noterm} IGNOREEXT CASE=allwords
