Rename: First letter in uppercase and rest in lowercase
With Rename CASE=firstword we can convert names to sentence style, that is, the first letter is capitalized and the rest are lowercase, but when names begin with numbers this effect is not fulfilled, all letters remain lowercase.
Example:
How could I correct this situation with regular expressions?
Example:
I have written:
Rename IGNOREEXT REGEXP PATTERN ([a-zA-Z]{1})(.*) TO \1 \2
but I don't know how to incorporate
CASE=upper
CASE=lower
or maybe it's not even possible.
Case changes are not supported. You'd need a script. There are few available on the forum.
Thank you very much @lxp for the information. There are really few scripts on the forum on the subject, I was analyzing one of yours, but I couldn't adapt it.
https://resource.dopus.com/t/renaming-capitalizing-first-letters-without-changing-following-letters/39883
Like so?
// https://resource.dopus.com/t/rename-first-letter-in-uppercase-and-rest-in-lowercase/46905
function OnGetNewName(getNewNameData) {
    var allWords = getNewNameData.newname.split(' ');
    for (var i = 0; i < allWords.length; i++) {
        allWords[i] = allWords[i].substring(0, 1).toUpperCase() + allWords[i].substring(1).toLowerCase();
    return allWords.join(' ');
46905.orp
Pretty much like
:wink:
Thank you very much @lxp for the effort, for the time, the result is almost perfect, but the way the script is, the first letter of all the words are converted to capital letters (Title style), but for me it was better at " sentence style" (only the first letter of the first word capitalized).
Here you go.
    var firstWordFound = false;
        allWords[i] = allWords[i].toLowerCase();
        if (firstWordFound) continue;
        var firstChar = allWords[i].substring(0, 1);
        if (!firstChar.match(/[a-z]/)) continue;
        allWords[i] = firstChar.toUpperCase() + allWords[i].substring(1);
        firstWordFound = true;
Now yes, perfect, perfect, perfect, thank you a thousand times @lxp!!! :grinning:
