Here are some Files Like
I want to Select them all & Press the Button.
The Button will Open the First Dialog box. In This Box I will Type The Album Name (example: Elton John Greatest Hits >>> Click Ok
Then The Button will Open Second Dialog box. In This Box I will Type Artist Name (example:Elton John) >>> Click Ok
The Button has to add a common String between Album Name & Artist Name (example: . Sang by. )
The Button will add incrementing numbers with first bracket example (1), (2), (3) at the last in the file name. After the click the button all file will rename Like:
Is this possible?
please, Someone, Help me!
IS THAT IMPOSIBLE WHAT I WANT? PLEASE HELP ME!! Dear Leo Jon
UPDATE
After 78 times Failed I find a way to do so, Is there any way to do the same things in a more easy way?
This code does what I want:
@filesonly
Rename NUMBER=1 REGEXP PATTERN="^(.*)(\.[^.]+)$" TO="{dlgstring|Enter Album name}{dlgstring|Enter Artist name|. Sang by. } ([#])\2"
@nodeselect
Thanks
