Rename help - adding sequential numbering in middle
Name of original file: cat.jpg
What I want to end up with: 12 24 2004 - 0001 - cat.jpg
I can't figure out how to do this. I of course can do the 12 24 2004, but the 0001....not having any luck. I am not very good at these.
If you have the date part already, here´s a hint, how you can place your sequential numbering:
[url]Rename sequential numbers at start of filename?]
One small addition to abr's answer:
Set the first "sequential numbering from" field to 0001 instead of 1, if you want the numbers padded to four digits.
Thanks so much, I was missing the fact that I still needed to check that box LOL. Now I can get to numbering my files :slight_smile:
