Rename help
I downloaded some rar files from rapidshare but now i have extensions ending all in .html. (sample1.rar.html, sample2.rar.html etc.)
how to remove .html
I'd try the Rename command.
*.html -> *
In future you might want to remove the html from the source URL when you retrieve it.
It usually gets there only when someone who is not familiar with RapidShare posts a link. In reality the file itself lacks the extension.
Someone download managers, including "FDM", will retrieve and save the file sans extension.
Then again, if it happens to you a lot a DOpus button solves the problem.
Thanks fellas.
