The following script allows you to rename multiple files at once, always displaying a preview of the possible transformation. The script has two translations: Spanish and English, which must be set manually from the Script Management window. Once installed, to run it, simply use a button in "Standard Function (Opus or external)" mode with the "RenameMax" command.
Rename Max.js.txt (88.6 KB)
Button.dcf (376 Bytes)
Note: The "Clean name" function (9th in the left panel) applies a series of corrections, one of which is "Name in sentence style" (capitalization of only the first letter of the first word). In the script settings, you can set the words to be excluded from this sentence style, that is, the words you want to always keep the same.
